1986 75 hp. mercury has many wires cut on motor harness
tony11905
Hi im really hoping someone herre can tell me where to download the wiring diagram for this motor this mercury is the one withe tan stipes if that helps its a 4 cyl , it a 1986 75 hp. . let me know what i should start doing, before going crazy , also has trim and tilt but that just clicks. when i hit the trim button on the controls.i would realy thankful for any help. thank you
carholme
Re: 1986 75 hp. mercury has many wires cut on motor harness
What is your engine s/n?
Gerry
tony11905
[What is your engine s/n? the serial number is as fallows ( A116699)
carholme
That s/n comes up as :
75 75 (R4) 4-cyl 6613221 0A197881 1985 USA
From here:
http://www.marinshopen.se/Motorer/O...Mercury2takt4cyl4085hp/tabid/487/Default.aspx
It is a model:
1075625 MERCURY 1985 75
Parts listing:
http://www.crowleymarine.com/mercury-outboard/277.cfm
Here is a link to the condensed version of the service manual. Let the page load for several seconds, then download soonest to your computer as the link is short lived.
http://web.ebscohost.com/serrc/pdf?...e-8d05-d15e12bbd92f@sessionmgr15&vid=4&hid=14
You will see that your s/n is the Thunderbolt without Disributor as seen in Fig M12-58.
Sorry I couldn't find you a coloured version.
Gerry
tony11905
still having no luck ,only thing i have from the controls to the motor is power but my trim and tilt is also still not working, and i just chaged the siliods for the trim and tilt, all it does when i hit the button is click ,so if you have or know where i can download a compleate wiring diagram from the tilt motor to the siliniods then to the harness or where ever i have to go to get it working that would be great. and any info on the motor itself would help as well ,theres power to it but that it wont tunr over ,wont click as far as starting dead , but motor is not seized and is in nuetral
carholme
I just checked the link and it is still working but you must have Adobe reader to enable you to see the files. Do you have this on your computer?
Gerry
