ronaldecole
Thread starter- Joined
- Jun 8, 2008
- 5
Can anyone tell me where the low and high speed carb adjustments are on a 1986 85 HP Force model 856X6M when you are in the boat looking at the throats of the 3 carbs. The Seloc manual I have -- (024-1) 1100 on page 4-20 fig. 31 shows a main fuel jet to the left of the carb and the idle mixture screw at the top of the carb but I am not sure of the relative position of that illustration. If I am standing behind the motor I see an adjustment screw on my left, so it doesn't quite match up to the Seloc.
The reason I am asking is because I am having a problem with the engine stalling on acceleration then hard to start. I believe it is fuel related since the electrical seems fine -- I've toubleshot the elctrical system using the Force troubleshooting guide and have a nice "blue" spark on each plug, along with new Champion plugs which are black when the engine is running.
The carbs were rebuilt by a marina last year for the same exact problem. I have been on the water 3 times this year without any problems then "bam" I was out last weekend and it started stalling and hard starting. I've been through the fuel system: the ball stays hard, I've already put a new diaphram in, rechecked all my hoses for snugness and leaks, checked linkage for binding and have been using fresh gas at the correct mixture and compression is good.
When I brought the boat back home that day it started right up with the muffs. But this is typical of what it did last year before the carbs were rebuilt - it would stall, not want to start in the water, but when I brought it back home it started fine.
Thanks, Ron Cole
Thanks, Ron Cole
