1986 85 hp force
tonyryan14
Took boat out today. Motor was shooting white steam out of the 2 small holes above the propeller and sometimes just hot air. Can someone tell me what causes this and maybe the cost to fix. Water come out before thank you
jerryjerry05
Re: 1986 85 hp force
There is no fix needed.That's normal.Send a check to Jerry.
Those holes are for a pressure relief system.Put in a new impeller.Just to make sure.J
USMCMatt
Mine does the same thing, completely normal, but having a fresh impeller is a good idea and cheap for the piece of mind
tonyryan14
when i first got this motor water came out of the 2 small holes
