1986 85HP Force Outboard Running w/Telltale added
DOUGLAS42
you tube stated info on this was in the forum but i could not find it
Re: 1986 85HP Force Outboard Running w/Telltale added
Ayuh,... Search the Force forum, or go back to youtube, 'n ask for a Link,...
MJS
Ok. I tried the impact driver on the plug with the flat head. After two hours one side of the plug broke off level with block. The seal of the plug is not compromised so no harm done other than im screwed on adding the tell-tale. Can I drill into the cooling system somewhere else?
stubtail
If you are prepared to "drill into the cooling system somewhere else", why not drill out the plug? Remember that it is pipe thread and not straight walled.
afarrens
BUMP and question -
what is the water temperature that you guys have coming out of your new fountain (thats what the kid calls it) LOL
