horiconducker
- Joined
- May 12, 2008
- 96
Thanks in advance for any advice, this may get a little long winded. My dad has a 1986 85hp force on a pontoon , was put away last fall running great. He went to put it in the water for the first time this year over the 4th of july and it would not start, no spark on any cylinders. I was not up north with him, and he didn't have an ohm meter or anything, but i walked him through the cdi electronics troubleshooting guide to rule out a bad ignition switch, kill switch and rectifier, but of course none of the easy stuff panned out, still had no spark. He ended up taking it in to shop to have it looked at. The shop told him the stator was for sure bad, they also said when the stator goes out it usually takes out the power packs too. He was told by the shop there is no way to test power packs untill stator is replaced. Shop said its not worth sticking the money into the motor to fix it, so my dad went and picked it up not fixed. My question is how common is it when the stator goes take out the power packs too on these motors? Is there a way to test the power packs with a bad stator? Dad called me wondering what he should do with the motor, if he should part it out or just throw it in a dumpster.I agree motor is probably not worth a new stator and 2 power packs, but it would probably be worth a new stator if that was all it needed.I am mechanically inclinded and could replace the stator myself, I've done it on other outboards and i have the tools to do it. thanks for any advice, ducker
