1986 9.9hp running slow :( Help!
treefort
Hi all,
I bought this motor a couple years ago and it ran like a dream last year. The guy recommended I use mercury oil in the gas but it is pretty hard to find so I am just using crappy tire 2 stroke oil for outboards. Problem?
Anyways, I took it out this year and ran it with the gas from last year. It ran poorly so I emptied the old gasand changed the spark plugs which were black and checked for spark. I also cleaned the carb and put the fuel/air ratio at 1.5 turns.
I took it out again and it ran pretty good until I was on my way back to the launch and going full throttle it bogged right down and stalled. When I started it back up it would die as soon as I put it in gear. A couple tries later I was able to limp it very slowly in gear. Soo, I took it home and ran it in a garbage can full of water and played with the air/fuel ratio a little. It seemed to run fine.
I took it out on the water yesterday and at full throttle it only goes about 1/3 or so the speed of which it used to!!?
I know very little about boat motors...so any help at all is greatly appreciated.
Thanks!
Wingedwheel
Re: 1986 9.9hp running slow :( Help!
Perhaps you sucked some crud into the carbs that was stirred up in your tank when after you started running old gas.
treefort
Hey, thanks for the reply.
I took the carb apart today and it was spotless. I also looked at the plugs and they were clean but had a little oil on them.
I am stumped..
treefort
I must have been stoned yesterday when I checked for spark because I think I forgot to turn the motor on.
Anyways, the ignition module is definitely outputting a better signal on the wire going to the upper spark plug. I swapped the two spark plugs, and then the two coils, and it is definitely coming from the module.
I tried checking the points to see if they are corroded but I can't get the flywheel off! I think I need a puller.
