1986 Bayliner bilge pump
bayliner19
After several years I decided to see if my bilge pump was still working. I put the plug in and flushed out the bilge, letting the water back up into the transom well. The bilge pump did not start :'(, I tried turning the manual switch on located on the dash but all I could hear was what sounded like a solinoid switch clicking on and off. Is there a simple way to check out the bilge pump without having to take it out :/, or is just taking it out and checking it the only/easier way?
When I was young the fish were so big we had to fish from shore with a tow truck line.
jtexas
Re: 1986 Bayliner bilge pump
sounds like a auto-reset circuit breaker...if the pump is clogged it'd trip a breaker or blow a fuse.
No,...... You Can't check the bilgepump til it's In Your Hand,.....
Pull it Out,....... I'm Betting it's Dead or Clogged......
Boatin Bob
As Bondo says plus once fixed please don't wait several years to test it again, this should be something done on a very regular basis!
