1986 evanrude 15Hp. impeller replacement
tobra100
Can anyone walk me through removing lower unit and replacing impeller?
Thanks.Ray
Cofe
Re: 1986 evanrude 15Hp. impeller replacement
To take the lower unit off,remove the 6 mounting screws and take out the lower shift connecter screw ,which will only be seen after all mounting screws are removed and the lower unit drops less than an inch,leaving an access opening for removal of the shift screw. Dont try to force the lower unit apart more than the inch,it wont drop entirely until the shift screw is removed.
Are you putting in the impeller or the whole kit?
tobra100
Whats your advice? Should I put the whole kit in? That was my first thought.
/ Should I put the whole kit in? That was my first thought
dazk14
Ensign
If you have to ask, then yes install the complete kit. Unless you've done quite a few, you won't know what parts can be re-used and the driveshaft to housing seal is constantly being missed by the impeller only guys.
