1986 force 125 trim issue
basspro1886
I have a 86 force 125 outboard. i have had a trim issue for awhile now, but cannot find a solution. At times it will not trim up on any of my switches throughout my bass boat. I have changed out the relays and still does not work. Sometimes it will work intermittently. I have put on new connectors a still the same issue. when i swap the relays it follows to the down side. I have went through 4 new relays thinking it was the relays. I can hold the switch up and flick the relay and then it will work. Not sure if I am getting enough juice to throw the pole in the relay. any suggestions
foodfisher
Re: 1986 force 125 trim issue
Clean "all" the wiring connections. Looking good is not good enough
jerryjerry05
Like food suggests.
Then replace the switches.along with the wire ends.
