1986 force 125hp outboard
jmar128
I’m having problems trying to wire a 1986 force 125hp to an ignition switch from scratch!
Any suggestions
Find the wiring diagram.----maxrules---or-----mastertechmarine.----Good luck.
jerryjerry05
This is from a 88 Force.
Should get you close.
Jiggz
Here's a wiring diagram for 125HP supposed to be good up to 1989 models. Ignition SW wiring is on the upper right side of the image. 125HP_thru89_eng wiring diagram.jpg
