jbwillis76
Thread starter- Joined
- Feb 20, 2009
- 36
Hi all! I've been lurking here for about a month and have been reading just about every post in the force section while I'm trying to get my first boat running. I will appoligize in advance for the long post, just want to be thorough.
I have a 1987 VIP 16' fish & ski with a 1986 Force 85hp outboard. Prop is a stainless 13x19. Here is what I've done so far.
Replaced fuel line, bulb and filter from the tank to the carbs.
Rebuilt the fuel pump
Replaced the water pump impeller
I've had it running for a month now. Cranks instantly and idles fine. Giving it gas it bogs and sputters. All this is on muffs, not in the water. Before I did anything else I wanted to get it in the water and see what REALLY needed doing.
I took it out yesterday and it cranked and idled fine. Putted around a little then I gave it WOT. After a good little while it finally planed out but my max RPMs are 2500. It ran at that max RPM for about 5 sec. then bogged out and would die if I didn't put it in neutral. If I put it in neutral it would run fine. I assume it's starving for fuel. I never looked in the tank and figure the pickup line or filter (if it has one) is plugged up.
I got it home and pulled the plugs (old ones) and the number 2 cylinder was clean. One at a time I checked for spark and all three cylinders where hot blue sparks. I checked the compression (cold) and they are:
1. 135
2. 135
3. 135
I was a little suprised by the numbers but VERY relieved.
Here is what I plan to do next.
Rebuild the carbs (one is leaking gas anyways)
Clean the tank.
Doing a link and sync (clymers manual) I know for a fact I'm not getting WOT at the carb. Butterflies a little over half way open.
Can anyone tell me why the 2 cylinder would be clean with spark and good compression? Also can you think of anything else I should be doing to get her running tip-top? And lastly for this boat and motor do you think it is over-propped?
When running it in the water yesterday It felt like it was running either on two cylinders or at half power. I'm hoping its just because the carbs need rebuilding and I'm not getting WOT. Any advise would be greatly appreciated.
Thanks for your time! James
1. 135
2. 135
3. 135
Clean the tank.
