Briand3096
Thread starter- Joined
- Aug 21, 2009
- 18
I just got a 16' Lowe Super V with a Johnson 40HP VRO. The motor had no fuel flowing so it was a no start. I removed the VRO pump and replaced it with the regular one. Now the motor runs but only with the choke lever up. It will fun forever but if you lower choke it stalls out. I used all new OMC parts and new fuel lines. I removed the carbs and cleaned them and I still had the same problem. After reading some post on here. I think one of two things # I did not clean the high needle and may need a tool to remove it. or #2 Possible reed valves?? Also do I need to remove the metal caps on the top of the carbs to clean that area?
Thanks, Brian
Thanks, Brian
