1986 Johnson 48hp wont turn over fast enough
NYGiants
Bought a 48hp johnson non running and I am trying to get it running. The motor will not spin over fast enough when the plugs are in to start, but with the plugs out it will crank over great. New battery ends, compression is good and the motor is in pretty nice shape over all. Any ideas? Primarily a fresh water motor. Tried a different battery as well
flyingscott
Check all connections and make sure they are clean and good grounds. If everything is good you may need to take the starter apart and clean.
NYGiants
why would the plugs being in vs out make a difference?
Honorary Supreme Mariner
With the plugs in the starter has to do some compression work.------Take the starter apart as it is elegantly easy to work on those starters.
