1986 Johnson water pump help
Crazy Joe
I can't find how to un-attach the forward and reverse shift shaft so I can remove the bottom end to replace the water pump.Any help appreciated.I got the Seloc manual,but,it doesn;t show me anything.
BonairII
Re: 1986 Johnson water pump help
It's probably up under the powerhead. Find the control cable that does the shifting...and see what linkage it is moving under the power head. That'll be the shift linkage.
hidef
What is the model number of the outboard? Different models have different procedures without knowing the model # it is very difficult to help you.
