1986 Mariner 40hp Timing Specs
logan_menk
Hey guys! I’ve been looking all over for the timing specs on my ‘86 40hp Mariner. It is a 6E9 serial number outboard.
If anyone has a tune up spec sheet I’d be grateful!
Faztbullet
Plugs....B8HS
Plug gap.... .024
Idle in gear RPM 900-950
Max RPM.......4500-5500
Idle timing .....2°BTDC +/- 1°
Pick up timing....6° BTDC
WOT timing.........22° BTDC.
Max timing is factory set and the stop screw has a red sealer on it. This timing does not go out of spec unless fingered with.
