I have an 86 Merc 115 outboard on a Astroglass 16.5 Bass Boat that has been out of the water for 10 years. I began by replacing or rebuilding the following:
Stator
Bottom switch box
Starter solenoid
Spark plugs
Fuel line with prime ball
Fuel pickup tube
Fuel pump (rebuild)
Carburetor (rebuild)
Cleaned out the fuel tank, replaced with non-ethanol gas, mix 50:1
Once started I fog oiled the engine as directed on the can.
I have spark at all the plugs.
Compression high is 130 and low is 121 psi.
The engine starts and idles well. As power is applied it powers up well through 3000 RPM. Above 3000 RPM the engine surges and misses. At times it blows puffs of smoke out the exhaust. After boat comes to plane I can power back to 3K RPM and slowly apply throttle and sneak up to 3800 RPM, but that?s it. I can feel it surge slightly as it runs about 40 MPH. I do not know where to go next, any suggestions are appreciated. I can post a video if needed.
Stator
Bottom switch box
Starter solenoid
Spark plugs
Fuel pickup tube
Fuel pump (rebuild)
