1986 mercruiser 260 350, what drive?
samm835
I have a 1986 merc 260 in my Sea Ray 268. I'm not sure what drive I have. Is there anyway to know before I pull the boat out? If the engine serial number helps it's 6817129.
Bt Doctur
Most likely a Alpha1 1.50 ratio ,double check the serial number. should be a letter too
samm835
Thanks Doc, is there a test that can be done on a heat exchanger to make sure its working like it should?
Bt Doctur
put air pressure in the raw or fresh water side of it and see if it holds
Pete104
It might be 1.5:1 but also may be a 1.32:1. The heavy duty gear set for big single engine boats.
samm835
Thanks Pete & doc, I didn't realize the alphaone was made in 1986, I thought (my ignorance) the alphaone was a newer type drive.
Ayuh,.... The Alpha 1 came out in '83, the Gen.IIs in '91,.....
