Crazydave1243
Thread starter- Joined
- May 12, 2010
- 26
1986 Mercury 115 six-cylinder will not run in the water. It will Run fine on muffs but will not idle in the water the only way to get the boat to move is Revit up in neutral and drop it into gear if you try to just ease into gear it will die every time i'll check the compression replace the fuel line and drained all the old fuel out of the tank still cannot get this thing to run on the water any thoughts are appreciated
