1986 Mercury 115
Marty Adam
I have a short that keeps on draining the battery. After three weeks of no use, the new battery is -0- charged.
I disconnected all accessories on the boat and still had a drain on the battery. I think that it is shorting in the motor electrical. What is the best way to isolate the short?
mr 88
Besides using a DVM and checking for continuity you can disconnect the wiring harness going at the engine and see if you still have a draw.It could be coming from a short in the controls/ign switch/gauges/harness. This way you have eliminated that from being the source, or it is the problem.
Chris1956
Sometimes rectifiers short to ground. You can check them with an ohmmeter.
