1986 Mercury 50 hp motor questions.
wvmedic
I just purchased a used 1986 Smoker Craft with a 1986 Mercury 50 hp.
Ser# A925548
How do I determine the model?
Also the motor needs a lower unit rebuild, I can buy a reman for about the same as it would cost me for just the parts.
If there is good compression are these motors reliable and worth spending $1000.00 to get the lower unit fixed.
Or should I shop around for a used motor?
Thanks from a new guy.
crem1
Re: 1986 Mercury 50 hp motor questions.
Hi!
Find the serial number, usually on the transom mount area of the engine, then go to the internet or buy a repair manual from Mercury.
If the compression is even for all cylinders and at least above 100 psi, then I would take a chance on a lower unit.
Alex
wvmedic
crem1, I posted the ser#A925548. Is this number not correct?
Thanks Jeff.
crem1
A925548, as far as I can find at the moment, is closest to 1986 2 cylinder, 35 HP
Alex
For 1000 bucks you should be able to buy 2 running engines. Why not a parts engine with a bad powerhead for a couple of hundred and then just change out the foot? Its not a hard project. Check craigslist. The serial number is also stamped on the top front of the powerhead.
wvmedic
Crem1, thanks for your replies. This is the info I have found as to what year and size the motor is.
Your MERCURY Selection:
50 (3 CYL.)
.... Ser # 6428681 THRU 0B122929...
Got it from usboatsupply, I was wondering what model it is. I have seen reference to Classic, Thunderbird, Black Max etc. that is why I was asking about the model.
Thefairlaneman, I will check craigslist but there aren?t a great number of boaters locally. I will check the surrounding area though; I would love to find one with a bad power head for a couple hundred.
Has this particular model motor historically been a reliable motor?
Thanks Jeff
