I am thinking about using
1 3/4" aluminized exhaust tubing for the fill tube on the 201, have it bend to fit down the gunwall and under the floor, then just use 6" of rubber hose to connect to the tank and the filler.
OK, I'm out of time out now...
Well, given the two options you provided, I'd go for the batts on the deck at the transom for more deck space
There is a fellas on iboats running an Islander rebuild who had like 47 different batt options:facepalm: What a dork![]()
i love the exhaust tubing idea if you can get it in the right size. std fuel filler hose i.d. is 1.5". i looked at exhaust elbows through Summit, JCWhitleyogni, PAS, etc but didn't see any small enough diameter to work so i ended up with copper water pipe elbows for the tight radius bends on the Starchief bow tank filler (no, they're not within 6" of any aluminum!).
you might be able to find the right size by cannibalizing a crapped out exhaust on an older furrin car, from back before their engines were producing 80 hp/liter....think a mid to late 70s corolla or B210
Two weeks at the lake!!!
Man that's awesome Glen, enjoy buddy!!!![]()
More photos of the destruction.
dozer, nice boat!!! I also have a SL series, but in a 16ft version, and I absolutley love it!! The floor is quite rotted in mine, and I would like to take it out this winter and re-do it; everything else is in excellent condition, and Ii would like to re-use it, including the carpet! (not even a sign of mold or mildew, though stripping it off may tell differently) my question is, how do the side "pads" come off. I see you have the same square "buttons" as mine, and I want to remove them with minimal damage, so they can be put back on and still look "factory" and not all screwed up.
Enjoy your post, and keep up the pictures comming!!!!
Man, sorry you had to come back to the real world Glen. Two full weeks of hanging on the lake and fishing - musta been soooooooo nice!
