1986 ss 201
Status
Not open for further replies.
barato2
Re: 1986 ss 201
when i saw those pix, i was having visions of an old blues tune refrain
BOOM BOOM OUT GO THE LIGHTS!!!!!
love that wiring. totally aside from the "minor" steering issues. but really, when some of our number have come home safe from outings with the steering working backwards, i don't see how awful a lttle thing like not being able to steer a 40+mph boat can be.....;)
Huron Angler
Re: 1986 ss 201
Just getting caught up here Glen, what a beauty you brought home:D:D
Congrats, hope this is the extent of the surprises for you. You've dealt with enough already, so you are due for some good luck.
Can't wait to see what you end up doing with the big girl.:)
dozerII
Re: 1986 ss 201
Have a few more beers and look at it again, DII. I'm sure the PO was in the tank when he "fixed" the steering and thought "better than factory now". Not like it could be a life or death situation. I think I see your trim problem too. He re-wired right after working on the steering and had a few more drinks.
Hey GA, I hope your right and he was in the tank when he did this, if he wasn't OMG.
My uncle once fixed his slipping rack with a pair of vice grips. It became a permanent solution when he bought a new pair of vice grips for his toolbox. QUOTE]
EZ I have acutally purchased a couple vehicles over the years that came with a rusty pair of vicegrips holding something together.
Dood, I was all ready for you to run this big girl the whole summer before you tore into her. Just the few things you pointed out coulda put a serious hurtin on the dozerII family
Even though I think Kanucks are all wierdos I'd never want ya to get all messed up and bloody man!:p
Smart move checking her out;) Glen
Now Now Jason, we are the Weirdos? , I bought this boat in Minnesota, and I know the PO did this repair long before he knew the boat was coming to Canada.lol
There you go Canuk bashin'!!!:D. We northern folk brought stuff like the telephone, blackberries and hockey!!!! So go easy man!:)
But seriously... good thing you found that stuff Glen.... those are not things to mess about with --- steering and gasoline soaked negative floatation!!!!
No one wants to see you splash and crash or splash and flash!!!
Jim
Thanks Jim, you forgot the all important BASKETBALL
That's a good one B2, the wiring is really not as bad as the others have been.
dozerII
Re: 1986 ss 201
Thanks HA, she is going to be a big project, I'm real glad I don't have to paint the whole thing.
Glen
dozerII
Re: 1986 ss 201
Well it's been raining so much here they have shut down a lot of the roads in the oil patch, so we are very limited for work. :D that means I can work on the SS.
Started attacking the demo some more, by pulling the port side windshield, bow seating and side panels. The consuls on this boat are a very different design in comparison to the smaller SS's. The top of the consuls are integrated right into the hull and the top of the gunwal. I cannot remove them with out drilling external hull rivets, and ruining the paint Yikes!! The side panels are also mounted in a differnt way but should not be a problem. Once I got the front seating and the side panels off I pulled the rear port side floor section 12 feet long piece of 1/2"ply. I then started digging foam, lots of water and at the front gas soaked.
dozerII
Re: 1986 ss 201
More photos of the destruction.
Second and third pics, if you can see all the black foam that is gas soaked, what a stink.
The next photo the yellow arrow shows another rotten spot in the fill hose where it was encased in the foam, that is the tird one.
barato2
Re: 1986 ss 201
that actually looks like rodent damage to your fill hose
dozerII
Re: 1986 ss 201
Hey B2, I wondered that as well there was signs of mice, but both the fill and vent hoses were completley encased in soggy foam.
Glen
InMotion
Re: 1986 ss 201
Man Glen, you that's a lot of digging there... holy smokes. It really looks like a huge boat inside now that you have removed most of the innards. Not cool about the gas though. I am surprised that the previous PO never stopped and went "why am I smelling gas all the time"? Good thing it's a bow rider... odds are, it would have been a reef at the bottom of some lake by now!
Interesting little square plates that join the sides to the bottom hull right around the the main rivet area that runs the length of the boat. I guess they wanted to make sure there was lots of strength.
Jim
dozerII
Re: 1986 ss 201
Jim
Hey Jim, Ya I'm tempted to try lighting a piece of the foam to see if it burns :facepalm:. The plates from the gunwal to the under side of the ribs is a feature they started sometime in the early 80's as the hulls were cracking at the end of the ribs.
Glen
jasoutside
Re: 1986 ss 201
I thought about dumping a bunch of fuel in my hull and lighting it on fire as a foam removal technique - then I remembered that the foam was entirely saturated with water and the alum hull would melt out before the foam actually burned:rolleyes:
dozerII
Re: 1986 ss 201
Hey Jason, that would work, that @$% foam would still be there and you can wrap some new aluminum around it, OH Right it's still WET.
Well the foam in this one went right to the stern under the trarnsom, quess what that looks like:eek: I spose now the motor has to come out so I can replace the transom too. Good thing I'm starting early on this one.
Glen
CheapboatKev
Re: 1986 ss 201
Not to mention the carcenigens released from that freaking foam....foam lung diseases...may as well be a glasser..lol
JD in Milwaukee
Re: 1986 ss 201
My 1979 22' Islander has the same setup.
GA_Boater
Re: 1986 ss 201
Boy Glen, she is a mess in all that foam with all the water and gas. I saw you have a 43 gallon tank. The last time it was filled up I bet it took 75 gallons and 33 gal. ended up in the foam. :eek: Given the clamp on the steering I'm surprised the fuel lines weren't wrapped with duct tape, One good thing - The paint on the outside of the hull is good.
dozerII
Re: 1986 ss 201
Hey GA, isn't that the truth. There was no way to know the fuel line was rotten, other than the smell of gas and mold. The only part visible was the last 8"s or so where it connected to the tank, the rest was encased in foam or behind the side panels. I'm real glad the paint on the hull is okay. I am planning on painting the top though as it is faded to badly to bring back.
Glen
dozerII
Re: 1986 ss 201
Took most of the day today but the interior is all out including that nasty foam. 18 large yard garbage bags full. Will be fun to figure out how to replace the floor in this monster, the sheets run bow to stern and the rear peices are 3.5ft wide and 12 ft long and end at the front edge of the consuls. Tomorrow I am hoping to get the last bits of foam scraped up and all the crap vacumed out. Then I can start on removing the motor.
Glen
InMotion
Re: 1986 ss 201
Glen that's a whole lot of garbage man!!! Wow! Good job. Interesting way sc chose to install the floor. No doubt you'll have it figure PDF out in short order. So pics of the cleaned and de-foamed boat would great to see!
Jim
jbcurt00
Re: 1986 ss 201
Although expensive, marine ply here is available in 12' lengths. I've tried to scarf plywood, with less then marginal results. Dimensional lumber, no problems, but the ply always seem to 'kink' at the end of the scarfs once glued up.... But perhaps it's carpenter's error, not the ply or the joint.
A few of the plywood boat websites have details for finger jointing plywood to make continuous run ply long enough to do the hull sides as '1 piece':
Laminating 2 sheets of 1/2 your final deck thickness" w/ staggered seams may be an alternative, if you have a 4'+ by 12'+ flat enough surface. The Starcraft hanger just might have some room available for this work:facepalm:
Based on previous work, it'll go pretty good & look great, however you get the deck in, so... carry on:)
dozerII
Re: 1986 ss 201
Jim
I'm going to load it all in the pick up for one load to the landfill to see what it all weighs, pics coming tomorrow, my arms were to sore to hold the camera still after fighting with all that foam, old guy you know.:D
Thanks JB, I think I will be able to use the same approach as on the smaller SS's, with doubles on the under side to join tthe seats and at reinforcement fo the seats. I'm having trouble figuring out how to do the two length wise joints where the side pieces meet the center section that need to be removable, but water proof.That is what soaked a lot of the foam was a poor design here.
Glen
Status
