1986 Yamaha 130 want to remove oil injection ???
fishon71
I have a 1986 Yamaha 130 and would rather mix my oil with the gas than trust this oil injection system. How do I disconnect the injection system? After that do I just run 50:1 oil to gas mixture like the old days? Am I crazy to want to do this?
WillyBWright
Re: 1986 Yamaha 130 want to remove oil injection ???
I never heard of any problems with Yamaha's injection system. There was an inline checkvalve update once upon a time, but I think that was about the only thing. And that was just an upgrade, nothing serious. The problems I hear most about involve early Johnnyrude VROs and Merc's pump drive gear failures. That was back around 1986. The American companies were playing catch-up. Japaneese outboards had them first (not including those funky Accumix and Autoblend gadgets).
fishon71
Any Idea when the USA started importing and selling big Yamaha outbourds (100HP & up)?
Ray Neudecker
The earliest models imported were 1984's. There were some oil injection gear problems with Yamaha through the 1986 models before changing the drive gear.<br /> Removing the oil injection from that model involved removing the parts including the oil pump and drive shaft for the pump and blocking the hoses to the intake.<br /> A plate is available for the oil pump hole off the consumer V-4 or V-6 models or a nickel and some DEvcon or JB weld can be used to block the hole.
fishon71
What needs to be done to a 1988/130HP to delete oil enjection?
Ray Neudecker
The 1988 model is almost identical. Same procedure as the earlier model.
mark n dark
disconnected oil system 11 years ago after changing power head.<br />removed eng drivin oil pump put plate over block<br />plugged line going to carbs removed all electrical did not rejet carbs <br />never had any problems<br />engine will smoke alittle more<br />plugs were change every 6mo.<br />ran the cheapest 2 stroke oil i coudld find usually havaline<br />mixed aproa 50-1<br />somtimes 75-1 with no problems<br />engine lasted 2000hrs before repalce with 4 stroke good luck
