1986 Yamaha 25hp doesn’t run good under a load
mattkline205
I have a 1986 Yamaha 25hp it’s the European model and it has a new fuel pump all new fuel lines under the cowling with a new filter new coil and I have cleaned the carb twice. It will idle perfect but when it’s full throttled it doesn’t seem to reach the rpms that it should it sounds bogged down. I figured it was a fuel pump because at full throttle I squeezed the primer bulb and it took off and the rpms sounded right so I replaced the pump but it won’t do it again even when pumping the bulb. Compression is 120psi both cylinders
Sea Rider
Was the motor running strong before or it's something that developed afterwords ? Being a 35 year oldie the current prop must be shot or in the process to become so. Start with a prop hub test to determine if the prop is working right. The primer bulb will remain fully firm only when it's fully primmed, once motor is running will soften a bit which is normal.
Happy Boating
mattkline205
I actually just bought the boat and the guy that had it before me said the motor was running great then all of a sudden stopped running good under a load so he replaced the fuel pump and cleaned the carb. How do I do a prop hub test?
Sea Rider
Remove the prop,
draw 2 straight lines at each side or 2 dots as seen, re install the prop, go for a wot run, remove the prop and check if both lines or dots have moved from where original were set. See if can draw a white line or dots with a marker or something appropriate. Hub slip failure it's very notorious specially when the prop powers heavy loads when at throttle...
Happy Boating
bbakernbay
Sea Rider - Thank you so much for sharing your immense experience, not only does it assist the original Poster but many others searching the same issue.
Sea Rider
You're welcome,
To the OP, report if with prop issues after the hub slip test to go from there.
Happy Boating
mike_i
Check the gas tank vent, is it open and clear? If you use a portable tank pop the gas cap open and try it. When you tested the prop as Sea Rider suggested did you do it in whatever body of water your boating in? The reason I ask is because you tested it and replied the results in less than an hour, just want to be sure you didn't run the motor in a tank or on muffs.
mattkline205
If the prop hub was messed up wouldn’t it just act as it was in neutral cause the prop would be slipping
Sea Rider
Depends, if 100% shot yes, on its way to become spun no, the hub usually takes some time to be fully kaput. As Mike 1 asked, where did you wot test the motor, looking at it, on muffs, open water ? What slips is the internal rubber hub, turns bad over time and use...
Happy Boating
mike_i
You want to do the prop test with the boat in the water, that's the only way you'll have the full resistance of the water and boat on the prop and hub. Do you know if your prop has a shear pin?
mattkline205
I’ll have to check about the shear pin. It’s seems to me like either a fuel issue or timing issue. Could the reed valves be messed up
Faztbullet
If you squeezed primer and it picked up RPM it not a prop problem. Nor will a spun or slipping hub cause it to be bogged down, just the opposite. You have a carb or fuel delivery problem.
mattkline205
That’s what I was thinking. I was just taking all the input I could get. I cleaned the carb again yesterday this time I used my air compressor along with some break clean so I’ll give it another go this afternoon
Sea Rider
If it's a non through exhaust prop should have a shear pin, remove the prop and check if in good condition, then check whatever comes to mind..
Happy Boating
mike_i
When he said he "squeezed the primer bulb and it took off and the rpms sounded right" that made me also think it was a fuel problem and suggested he check the vent and open the gas cap. Question to the OP, why did you replace the fuel pump, fuel lines, coil and clean the carb? Did you have the problem before you did all of this work or did you do it because of the problem?
mike_i
OK now I'm back to my original guess that it's a fuel problem. What condition is the primer bulb in when the motor bogs down? Are you running the motor on a portable tank? If so have you run the motor with the gas cap off or confirmed the vent is clear?
I replaced all that stuff because of the problem to see if any of that would fix it
mattkline205
The primer bulb looks brand new. And the gas tank is a portable tank but there is no vent buiilt in to it so when I run it later I’m gona try with the cap off
mike_i
When I asked about the primer bulb I should have been clearer. By asking the condition it's in I should have asked if it's puckered as in sucked in or compressed or hard when squeezed or soft where you're able to pump fuel thru it until it firms up.
