1987 140 vro power pack, rectifier, stator issues
dsen
Can a bad stator cause power pack or rectifier to fail. Had a power pack fail 2 times in 2 years. Replaced power pack and went to lake. Now no charge and erratic tach.
I am replacing rectifier to fix charge and tach but now wondering what is causing all of these problems. Dont want to spend money on stator if not needed.
Did a bench test on stator. ohm test between yellow/grey and yellow. tested .80 oms. manual says should be .60 to .64. Is this something to be worried about?
Thanks in advance for any help on this.
Darrell
boobie
Re: 1987 140 vro power pack, rectifier, stator issues
Ohm tests will vary due to air temp. Sounds like a bad rectifier.
dsen
Thanks for your reply. One question, can a bad stator cause power pack to fail? Also, what are the symptoms of a bad stator?
Thanks,
Darrell
