If water is coming out of the pee hole does that mean that the thermastat is working? If not how do you tell? Had it runnig for over an hour today in a barrel and ran fine. Yesterday it killed on me and would not start. Found the rubber on the cam roller that is on the carb was gone. So it does not get hit even when you have the throttle as far as you can in nutruel. Pushed it over with a srewdriver and it started up.
Used it this morning and it ran but I could tell it was getting hot.The pee hole had a constant flow coming from it. Could see steam coming from the hole on the back side. Took the cover off and water hit the engine and it sizzeled, so i know it was very hot. Plus i could tell it was losing power. Not sure what to do next. Was told the pump was only a year old.
