jshoe
- Joined
- Jul 24, 2015
- 14
Engine Serial # B648030 I have a problem getting the boat into neutral. Checked cutout switch timing and adjusted. Replaced the lower shift cable.Had a professional boat mechanic adjust the linkage. I measured the lower shift cable for excessive play and it was supposed to measure 9/16" or less and it measured a little under 12/16". Checked the remote shifter and upper cable and the manual said to measure the cable end movement from forward to reverse and it measured 3 1/8" which was just within limits. According to the manual it is a problem(?) with the gear case shift spool assembly. I am wondering if that is likely and if it makes sense and if so how to correct that problem. It has been years since we have been able to really enjoy this boat. Help, please!
