1987 - 175 HP VRO pump replacement
Gotts
Hello Everyone,
Just a question for anyone of you folks about a replacement fuel pump for my VRO. I'll be disconnecting the entire original VRO this summer. Surprisingly, it's running extremely well, but I think it's time.
Would any of you have the type and part number for a fuel pump? I realize I'm going to have to create a bracket and replace the vacuum limiter with a brass nipple, but I think it's a safe bet, unless any of you think different.
Again, Thanks for your help.
rusty reel
Re: 1987 - 175 HP VRO pump replacement
Ihave a 120 evenrude that I believe the fuel pump went out on me and I want to remove the VRO system. I see you mention a vacum limiter. I assume that the fitting that I see on the bottom of crank case?
Gotts
Sorry Rusty. Yes, the backfire arrestor.
Any idea's?
seahorse5
If you want to replace the "VRO" with a regular fuel pump system, you will need two pumps and all the plumbing. Each pump is close to $100 apiece and you can order the parts used in a 1983 200hp model.
Your best bet besides buying and installing a new "VRO" is to use your old one as a pump and premix your fuel. New diaphragms are available for it.
tashasdaddy
there is also a new premix pump, to replaced the VRO # #5007422
Gotts
Thanks Guys, I appreciate it. I thought I had seen the replacement part somewhere in the forums.
How long does it normally take to replace, ( considering everything goes as planned)?
Thanks again.
:p
