1987 19ft 4.3 merc prop size
Status
Not open for further replies.
Clarko1988
I just need to know what the best prop size would be for this size of boat. Thanks in advance.
Scott06
do-you have a prop on it currently? And if so what prop is it and what is WOT rpm?
best is a relative term depending on how you use the boat.
generally for basic all around performance you will have a 19” thre blade aluminum black max type When sitting on a dealers lot, maybe a 17” if its heavier and has a 2 bbl vs the 4 bbl carb.
there are a lot of variables though like outdrive gear ration, weight and beam of boat , how loaded down the boat is.
Clarko1988
So i had to put a spare prop on it and its 13x13 and barley moves the boat. And feels like it slips at higher rpms not sure of the wot.
jbcurt00
See prop discussion
Status
