damian1955
Thread starter- Joined
- Oct 28, 2013
- 14
Can I remove the shift assist module if I keep the RPM's at 600 ?
Howdy,
Welcome aboard!
Um, no, not really. The Shift Assist System causes the engine to "stumble" by pulsing the ignition. This allows a similar torque "pulsing" that allows you to get the drive out of either REV or FWD gear.
Getting a Cobra out of gear requires either cable tension or pressure that can be excessive if the ESA system is NOT used.
Excessive out of gear force will eventually damage the lower shift cable.
Regards,
Rick
If it's shifting hard??
Possible: the flapper in the exhaust has melted and fell into the shift mech.
The shift cable needs replacing.
The bellcrank has corrosion around the pivot points.
Unhooking the ESA is dangerous.
A friend with a 28ft with the King Cobra.
He unhooked it and ended up docking his boat ON the community pier in Annapolis,Md.
