1987 21ft Wellcraft shifting problems/Please help
coyotehead
My boat has a alpha 1 out drive and a chevy 305 engine...
She will shift in to forword but no reverse,doesnt even click in reverse...
I can drop the lower and it will shift forward and reverse but not with cable...
coyotehead
1987 Mercruiser Alpha1/Service manual
Can some one give a link or tell me where to find a down loadable service manual for 1987 model mercruiser alpha1
Evinrude Boater
Re: 1987 Mercruiser Alpha1/Service manual
Did you have the lower gear case off the upper gear case recently? You have to put the throttle into full forward when you remove the out drive from the bell housing or slpit the upper from the lower gear case..
coyotehead
Re: 1987 21ft Wellcraft shifting problems/Please help
Yea,we took the lower off to make sure we even had reverse before going any futher...Im new to boats and this is my first fixer upper...
Thanks
slydog75
Why did you start two different threads about the same thing? You're just goingt to confuse matters and make helpful people work harder than they need two if they answer you twice without realizing it's the same person.
coyotehead
Thats my fault buddy..I am new to this whole forum thing...Sorry about that....Can you help me with my shifting problem?PLEASE!!!
