DRCrowe
Thread starter- Joined
- May 22, 2018
- 84
I just rebuilt my VRO pump with a fuel side rebuild kit on my 1987 Evinrude 225. When I took the pump apart I found a torn diaphragm. I replaced all of the parts that the kit included except a small blue o-ring, large o-ring and duplicate parts (because they sent me 2 different kits and each kit had a duplicate part). The manual states that a plunger o-ring should also be replaced but I didn't see it in the kit unless it is the little blue o-ring that I didn't use (it didn't look like the right o-ring)
I put everything back in the boat, bought new snap clamps and hoses. I pumped the ball and fired the boat up. The only problem is the pump isn't pumping. The boat will run as long as I pump the ball but dies after about a min or so when the float bowls empty. It worked better before with the torn diaphragm!
I confirmed that everything is back where it is supposed to be with before and after pictures!
I am attaching pictures of
1. The parts I got (with notations)
2. The plunger o-ring in question that I did not get and am wondering if it should be replaced (with notation)
3. The current installation of my VRO Pump
4. The torn diaphragm just for fun!
Any suggestions would be appreciated!
