1987 3.0L Mercruiser Alternator Belt Always Comes Loose
Searay87
Re: 1987 3.0L Mercruiser Alternator Belt Always Comes Loose
10-4 Don. Thanks. Not sure if I'm up to doing this myself. I'll probably have the local merc dealer do this and get them to zip tie in an extra belt and leave it off so I can sand and paint the pulleys myself. I appreciate the expert advice (and the patience for the dumb questions..)
Bob
fishrdan
I don't know what you mean by opposing wrenches on the pulley bolts.
Pull wrenches together, 1 bolt will loosen
Next, borrow or rent a "Port a power" and use what ever ram you can get under the pan with a 2x on top to protect the pan.
I was able to weasel a small car scissor jack under the pan of my engine, chunk of plywood on top of jack.
achris
More fish than mountain goat
Bob
Pulling and replacing the drive is easy... Have a look at these, then make your decision...
Removing drive: http://youtu.be/w3O63YTOhn8
Checking alignment: http://youtu.be/w118LGsYgY4
Installing drive: http://youtu.be/aGVrY4cWiDA
Chris.....
