1987 35hp Johnson dry weight?
25-06
I am purchasing an 1987 35hp Johnson, that the seller says weighs 191lbs. Can this possibly be true? :mad: It is a long shaft, rope start, tiller model without trim/tilt. Thanks!!
rayodunne
Re: 1987 35hp Johnson dry weight?
A 1987 30HP weights in at 123lb so yours should be similar.
Palssonater
Isn't the 35HP the next size block up from 25HP and 30HP? 35HP is same as the 40HP I think.
25-06
It weighs 191lbs, largest 35hp i have ever seen, I wonder if this plus my 67lb kicker will be too much stern weight for my 16ft Lund?
