1987 4.3 omc removal
ciera
have to remove engine from boat 1987 sunray 21 foot cuddy 4.3 omc what do I need to do to get engine out after wires and hoses are removed
do I undue the bellhousing bolts and pull straight ahead not sure on how to remove I will be using a tractor loader to pull engine out
thank u for all your help
pull the drive, then unbolt the bellhousing from the transom plate, then undo the lag bolts in the motor mounts.
you need to pull the drive anyway to realign. might as well pull the drive now and save yourself about 2 hours pulling the motor.
