1987 45hp classic fifty carbs.
Spillman1979
How hard is to remove the carbs on this motor, and how would one go about cleaning them? Any help would be great, thank you.
GA_Boater
A manual explains how. Got one?
Cleaning means rebuilding with 2 kits, one for each carb and soaking the disassembled carbs in carb cleaner.
Spillman1979
Thank you, I do have a manual actually two to be exact. I was just wanting everyone's input.
Your best bet is to post what your motor is doing / not doing !----------Often folks want to start with the carburetors for some reason ?--------------What other trouble shooting has been done that leads you to believe there is a carburetor issue ?
Spillman1979
Compression check was 120 in all 4cyl, spark test showed great spark on all. I replaced the propeller with exact one that came with engine. Engine runs fine on muffin in driveway in gear and out. I have ordered a new fuel pump rebuild kit but hasn't came yet.
