1987 50 force outboard
fish_addict707
Hi, for some reason, the motor is only going about 5mph an hr.. I took it out for about a 30 min ride and on the way back it started going slower and slower to about 5 mph..Any suggestions on what I should fix? Ive done spark plugs and tubing... anything helps. Thanks
jerryjerry05
Re: 1987 50 force outboard
More info:Still running at full throttle? RPM"s?
Check for spark and compression.Then check the prop.J
