1987 50 hp Merc dual ram trim/tilt stuck in up
Capt_Bill
I need to locate the Release screw(s) to relieve the hydro lock ?
On a 1987 50hp Merc dual ram trim/tilt
Capt_Bill
Locate Release screw(s) dual ram trim/tilt
Need to locate Release screw(s) dual ram trim/tilt
1987 50 hp merc. Has hydro lock engine won’t
go down . trim/tilt motor/pump works fluid level full
merc850
Sounds like the pump isn't working because it pumps fluid into the down side of the ram. All I can say is remove the bleed screws and push it down.
Anything under the pump / reservoir inside the boat ??
