keepNitreel
Thread starter- Joined
- Aug 21, 2008
- 446
The motor is a 1987 50 hp force 2 cylinder, model 507x7b. I have a manual but it does not cover this problem. OK heres the problem: When I turn the key the starter engages the bendix to the flywheel and it will rotate some then stop, rotate some more then stop, so much that the motor wont turn over. I have turned the flywheel by hand and it seems like I can feel when the pistons reach the top and bottom of there cycle. The first battery I used was weak and would not send the bendix to the flywheel. I found that the battery would not hold a charge so I used the battery from my SUV and it still would not turn over. Should I take out the spark plugs and spray some W/D 40 in the spark plug holes? By the way I got this motor about a month ago and this is the first time trying to start it and have never seen it run.
