fisherrick
- Joined
- Jul 27, 2009
- 21
Having a no spark problem on 87 Johnson J70TLCUR. Stator is a 582730. Powerpack is a 583143. Timer is a 582724. Between Seloc and CDI, I can not find a test procedure to match what I have. Don't have OMC manual on this engine.
I get low resistance of 10.8ohms between pin d-a, d-b and d-c on the timer. This is supposed to be 35-47 ohms. Yet the DVA is supposed to be .6v+. I'm getting 1.6V to 1.8V. Even with the low resistance reading, the dva is well above minimums. My guess is that the timer base is good.
Next step is to test stator between brown and brown/yellow and between orange and orange/black (according to CDI). I don't have orange or orange/black. I have standard brown & brown/yellow, and yellow & yellow/gray. However, resistance test on brown to brown/yellow shows open circuit and no dva output.
Wiring diagram shows connector with black/yellow (kill) on output side of pack with the 3 orange coil wires (no connector). Actual engine shows kill wire on connector with brown wires between stator and pack and orange coil wires directly out of pack w/o connector. Kill wire checks out as to short to ground, (key off), and open circuit, (key on) @ this connector, so key switch and dead man switch should be good. (tested control box on another engine..checked good).
I have been jumping the solenoid w/ key off or on. No Spark. Jumped solenoid with main Red Plug disconnected. No Spark. Can't test the pack until I'm sure the stator is bad. Of course, checked with everything hooked up w/no spark using key switch. Certainly don't want to just throw parts at it until it works. So....
1 Charge coil is part of the stator Yes/No?
2. Charge coil is test on two brown wires. Yes/No?
3. Charge coil bad, stator bad. Yes/No? (charge coil molded into stator)
4. Timer holds sensor coils only. Yes/No?
5. Checking the pack can not be done until the charge coil is putting out (good dva from charge coil to pack). Yes/No?
6. Charge coil should put out whether timer is connected or not. Yes/No?
7. Does anybody out there have a test procedure from OMC Manual? Hopefully the wiring diagram will match what I have.
