skipper123
Thread starter- Joined
- May 17, 2010
- 74
What would be the order we should go to fine tune a engine. As in Mine is now running good at idle and good at WOT but runs rough in between. Just bought the motor a couple months back and found a bad switchbox and trigger. I have replaced thoes as well as plugs. During the process of finding what was wrong I turned the idle screws on carbs and think I have that screwed up. It ran good the first day or two when I bought it from idle to WOT with no hesitation until the switch box went out from shorted wires on the trigger. I tried to adjust carbs yesterday without much luck. Started at 1 1/2 rounds out and worked from bottom carb to top turning in until stumble and then back out until smooth idle. I have been reading that the timing will need to be set after a trigger replacement and trying to learn how to do that right now. Im just no sure what order I need to be going in as in timing, carb adjustment, link and sink ?
