74bayliner
- Joined
- Aug 23, 2011
- 607
I am really confused, i figured maybe the impeller was bad, after replacing it, still no water coming up through the leg. The first time i tried the water line was just above the intake holes, the second time i tried the water was coming through muffs...
Am i missing something? I took the leg down again and its hot and no sign of water.... so somewhere between the intake holes and the impeller there is a blockage?
I watched a Dangar Marine video and he talked about a certain outboard not having a self priming pump which means that the motor had to be deep enough in the water with the waterline closer to where the impeller is for it to make vacuum and suck up water. Is this the case with this motor?
If that is the case than i have to put the motor back onto the boat and put it in water to do any further timing/carb setting.
Is that correct, this is really bumming me out.
the motor starts and runs, I checked compression (118-115-110 ) 1,2,3 in that respective order, i replaced the spark plugs, changed the gear oil. Just wondering why its not pumping water (no water was coming from the 2 exhaust holes or from that plug by the thermostat (didnt run it too long since it wasnt pumping water didnt want to do damage.
