retiredmrbill
- Joined
- Oct 1, 2010
- 4
I made a dumb *** mistake and put lube on my flywheel key and stud after replacing my trigger and stator. It ran great until I increased the rpm's and spun the flywheel. It broke the key and left some pretty big grooves on the spindle and inside the flywheel. I cleaned out the key chases on both and got a new key. I had to take the dremel to the inside of the flywheel to smooth it out to get it to reseat. I got it back down on the shaft but I noticed a slight wobble in the flywheel even though the nut was on. It ran well but I am concerned I may have ruined the flywheel. Does anyone have experience with this and should I replace the flywheel to be safe? Everything else seems good. Thanks
