1987 90hp Johnson TLCU Oil Injected?
Hondo65
Is the above motor oil injected or pre-mix? Any known issues with this motor?
Thanks, FNG here. Will probably be asking many more questions coming up as I will be aquiring a new to me boat.
Thanks
Hondo
tashasdaddy
Re: 1987 90hp Johnson TLCU Oil Injected?
from the factory it had the VRO pump. whether it is still connected i don't know. the pumps are expensive, and when they go, a lot of people replace it with a regular fuel pump and premix the oil and gas. i had an 88 that was a fantastic motor.
psehunter
TD Do u have to replace the pump or can u leave the old one on it?I have an 1985 90 hp rude and I might need to know one day.
tashasdaddy
if you have the original pump, i would cap off the oil line, and disconnect any oil alarm. those original pumps were known for failure on the oil side. you can premix, and use just the fuel side. or you can go with the straight fuel pump of the 88spl, and premix. or you can upgrade to the VRO2 mixing pump.
