1987 bayliner 17ft capri plus 85hp force o/b
cairngorms
im looking to replace the fuel line which runs out of the integral tank, but i have no idea how to do this and i don't want to just pull and see what happens. Also the working space through the battery compartment is very tight and i cant see an obvious way to remove the fuel line.
Any help would be really appreciated.
Thanks.......
foodfisher
Re: 1987 bayliner 17ft capri plus 85hp force o/b
Got a pic.? Most replaceable parts are accessible, though it may be a squeeze.
NYBo
There is a large opening into the underside of the splashwell from the cockpit. You'll see the fuel line fitting on the top of the tank. Undo the hose clamp and pull off the hose. Pull.
