grizzreaper
Thread starter- Joined
- Oct 8, 2007
- 160
hello i had my boat out yesterday, started a little rough.gave it some throttle n let it warm up a bit. noticed my temp gauge isnt working but oil,gas,and rpm is.not sure how to change temp gauge, but this isnt my main problem. we cruised around a bit felt grt. after 20 mins or so i gave it full throttle, rpms went to 2500 to 3000. thinking to myself this is fast but not 40 to 50 mph fast. we went thru a canal with a no wake zone. i idled thru and got to the other side, full throttle and wham it went to 4500 to 5000 and we were cruising. i adjust the trim and after say 10 mins without me touching the throttle it just died, had power the motor was still running but no rpms or speed. i grabbed the throttle and eased it back to middle n slowly pushed it forward and had no more probs for a bit. we trolled around for 20 mins or so , then went to full throttle and wham it did it again. then again a 3500 and 3000 rpms. if i stayed around 2500 rpms and under no isssues at all runs grt. no sputters no shakes. my concern here was i could not see the water coming out of the drive like you do on a outboard. too different animals i know but it still concerns me. not sure if it comes out of the prop or not.going to change plugs, cap ,rotor, and plugs to see if that is my prob or is my prop slipping at a higher rpm. thanks in advance for all and any help on all of this.
