Got first six bolts installed and determined remainders needed to be longer than what I had purchased. Will have to pick up more during week to get transom installed all the way. Also did water test as it was finally not raining. Trouble areas sealed up well with G/Flex, found two other weepy spots that will need to get addressed. Cautiously pumped about motor. Really didnt know what to expect as po had purchased boat in pretty much state I had gotten her in. He had plans of re-doing her but didnt get to it. He said motor ran when he bought it but never had it out on water. Gonna spend some time in the Force Forums and see what I can find out.Just checking in on you... Glad you go the motor to fire... The cooling part (water flow) can often be a routine/easy fix (new pump/impeller)...I'll be hoping that's the case for you...
I wish I had seen your post above about Gluvit.... Gluvit and Marine Tex (while both epoxy) are very different... However, all's well that ends well, because it sounds like you got your hands on a really good product for the job.
I'll try to check in more often..
PMC
So...the plan that I had for the long weekend didn't exactly go the way I wanted. We made forward progress just not what I had hoped. Maybe the Guy with the master plans way of nudging me. It was a good weekend all in all, time with family, time with the boat, time to think about those that have protected the freedoms we enjoy, and an extra day off of work. We were able to get the splashwell out. That really made a difference working in the transom area. Should have thought about that earlier. Guess I was a little intimidated/scared about it coming out. It came out in one piece and made riveting and clean-up much easier.View attachment 195784View attachment 195785 We were able to get both transom skins cleaned up, straightened, filled any voids and sanded down. We still have to prime and paint. We got the angle riveted back on that holds the transom.View attachment 195790. . View attachment 195791 We also got the rivets back in that we had to drill out in order patch port stern corner. We need to gluvit the boat yet but are going to have to wait on weather for that.
Once that was done and scuffed started to apply an automotive gravel guard or chip protector. Thought process here was we had some of this around from when we did bodywork at the shop, was not gonna be used, and thought it would provide some protection for on/off trailer, running down the road, and if we want to beach or have to beach the boat.
Will topcoat with a Ford white and then clearcoat.
Second picture will give you an idea of what finish is like. If I had to do it all over again I would have eased up on coating a but and gone with single stage or rustoleum type product. Materials were basically free. In the sun it looked as if I had good coverage, even had Joe look it over for light spots or misses. While I was clearcoating sunlight changed and saw a few areas that needed more base. With light fading I finished up clear and will deal with light spots later. Was trying not to have to wait for a long period for drying but, live and learn.ecauMine was a bow mount tank and it is 19 gallons, I would tell you to test out the sender in the tank to make sure it is functioning. Procedure is here in forum in a bunch of threads.I have a 1988 Bluefin sportsman 1950 with a 140hp inboard I was wondering if any of you guys can tell me what size the gas tank is? also possible ways to fix gas gauge and speedometer as both are not working. thanks in advance
Decide to get wider axle and make new xmembers to fit new axle and hopefully get boat lower on trailer. So far dis-assebly has started and fabrication has begun.
Will have more as things progress. Hopefully rolling by the weekend. Wish me luck!
The trailer got approx 18'' wider, which I'm hoping will get the boat lower on the trailer and make for better tow, launch and load. Looking forward to finishing up the fabrication part and see how the boat fits. Then prep and paint. Hope everyone had a great 4th of July.
Sorry for the dark and mysterious photos. Shop light were off and I thought there was enough light coming in thru windows. Tomorrow hopefully the toungue.
