1987 Chris craft Thru Hull
davidonmars
Hey hows it going just picked up my first boat a 1987 Chris craft 210 Limited with the OMC 5 litre. I've done all my research about these OMC and this one does have the updated red shift cable and it shift smoothly. I want to do a Thru Hull exhaust on this. Is there a place I can buy just the block off plate? I have plenty of hose left over from when we did my friends Mercruiser Thru hull exhaust so I can probably just use that to run to the transom and get some exhaust tips. Thanks
Don S
Re: 1987 Chris craft Thru Hull
Yes.
davidonmars
is there just no room or what is the reasoning
Ayuh,... Even if you could reach the bolts, the y-pipe ain't coming out, unless the motor is outa the way...
