1987 Evenrude 60HP VRO with water coming out of the block
Teepster
I started my 1987 60hp VRO yesterday (with water ears ) for the 1st time after the long winter. Started up and pumping water out the normal outlet fine. I then noticed water running down the side of the lower unit housing. It's coming from the side of the engine block. I can see where it's leaking from and its near a gasket seal.The metal piece where the water is leaking (and with a gasket) is about the size of a book on the side of the motor near the back. I found online a parts breakout of my motor and I believe the part in question is the Exhaust Manifold cover. The gasket for this is only about $6 and looks like about 15 bolts holding the manifold cover on and fairly accessible.
I didn't notice this last fall and the lower unit should have drained properly since I fogged the motor in the fall but I did have the motor tilted up for the winter before I covered everything with a tarp.
My question is do you think this is just a gasket replacement or when I take over the cover will i find more serious issues. Don't seem like coolant water and exhaust manifold should coexist,
Teepster
I just looked at the engine more closely in the daylight and there is definitely a water line coming out of the exhaust manifold housing so there is water behind it. Looking at the gasket on line shows several compartment gasket cutouts so I'll know more when I remove the 15 bolts and inspect. I just ordered a new gasket. Surprisingly inexpensive.
