LukeWilson
Thread starter- Joined
- Jul 4, 2011
- 5
Heys guys, new here and fairly new to boating but I'm fairly mechanical. Just finished doing the floor and transom in an '87 Checkmate Predictor and now i'm having some issues with the motor.
At first it would run fine at low rpm, but would bog out at higher rpm after 15 seconds. I pulled the carbs apart (which appeared very clean), stuck them in the ultrasonic and replaced the primer bulb. It ran much better but i was still only getting 40mph and slow to get up on plane. I found that the spark advance was being restricted by a cable holding bracket today and took care of that issue. I went out and it really helped, boat popped out of the water great and really seemed to scream along. Then it shut of on me, it came to a pretty quick hard stop. Eventually i did get it going again but it has a really rough bag or rocks sound to it and i'm afraid im doing some kind of damage.
Water outlet seemed slightly less after the shut down, before it was a fairly hard jet and now it is only a constant stream. Compression test was 125 across the board before and after i had it going. I also appear to have very good spark on all the cylinders. Nice little cloud of smoke on start up leads me to believe it's getting oil.
Any thoughts?
Thanks guys,
Luke
Any thoughts?
Thanks guys,
Luke
